cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS BE249QLB 23.8" Full HD Widescreen LED Monitor Built-in Speakers, DVI-D, VGA
Availability: Out of stock
  • Aspect Ratio: Widescreen - 16:9
  • Resolution: 1920 x 1080
  • Brightness: 250 cd/m²
  • Contrast Ratio: 1000:1 / 100000000:1 (dynamic)
  • DVI-D, VGA, DisplayPort
£227.99
0% interest for 4 months
Learn More>
£227.99
Product Description
Designed for Enhanced Productivity
- In-plane Switching panel with wide viewing angles and LED backlight for quality visuals
- Extensive connectivity with DisplayPort, DVI-D, D-sub, Audio in, Earphone jack plus USB 2.0 ports for the most flexibility
- Advanced eye care feature with Low Blue Light & Flicker Free Technology
- Ergonomic design with tilt, swivel, pivot and height adjustments for a comfortable viewing experience
Vivid, lifelike visuals with 178° wide-view angles
BE249QLB LCD monitor features a Full HD(1920x1080) resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
Extensive Connectivity
BE249QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, Audio in, Earphone jack, and two USB 2.0 ports.
Great Viewing Comfort with Eye Care Technology and Ergonomic Design for Everyday Computing
Say goodbye to tired, strained eyes. ASUS BE249QLB features ASUS Flicker-free and Low Blue Light technologies to reduce instances of eyestrain and other damaging effects when spending long, countless hours in front of a display.
ASUS Flicker Free Technology
ASUS Flicker-Free Technology by using Smart Dynamic Backlight Adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, and brings comfort viewing experience to avoid Computer Vision Syndrome.
ASUS Low Blue Light Technology Blue Light Filter
The latest ASUS Low Blue Light Monitors allow users to access four different Blue Light Filter settings onscreen, which you can choose from level 1 to level 4, depending on different tasks, to effectively reduce harmful blue light from the screen for the best viewing comfort.
Versatile Comfort with Ergonomic Stand Design
With an ergonomically-designed stand with tilt, swivel, pivot, and height adjustments, the BE249QLB provides a comfortable viewing and usage experience. The ability to pivot the screen clockwise or counterclockwise 90 degrees for use in portrait mode comes in handy when working with long documents, coding or website browsing. Furthermore, the BE249QLB features a quick release stand to provide an easier way for frequent VESA wall mount scenario setup. Screw-free and its done in seconds.
Bundled with the MiniPC kit
ASUS BE249QLB monitor is bundled with the MiniPC kit for those who need to mount mini PCs on the monitor, to make the desktop clutter-free and space saving .
Specifications
Specifications
SKU 90LM01V0-B01370
Compatible Brand ASUS
Model BE249QLB
Reviews
Related Products
