cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS DUAL-RTX3060TI-O8G-MINI NVIDIA Geforce RTX 3060 Ti 8Gb GDDR6 Graphic Card
  • NVIDIA Ampere Streaming Multiprocessors: The building blocks for the world’s fastest, most efficient GPUs, the all-new Ampere SM brings 2X the FP32 throughput and improved power efficiency.
  • 2nd Generation RT Cores: Experience 2X the throughput of 1st gen RT Cores, plus concurrent RT and shading for a whole new level of ray tracing performance.
  • 3rd Generation Tensor Cores: Get up to 2X the throughput with structural sparsity and advanced AI algorithms such as DLSS. These cores deliver a massive boost in game performance and all-new AI capabilities.
  • OC Edition: Boost clock 1710 MHz (OC mode)/ 1680 MHz (Gaming mode)
  • A stainless steel bracket is harder and more resistant to corrosion.
  • A 2-slot Design maximizes compatibility and cooling efficiency for superior performance in small chassis
  • Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure.
  • 0dB Technology lets you enjoy light gaming in relative silence
  • Pre-Register your Product to find out when the product will be available for pre-order/order
£541.99
0% interest for 4 months
Learn More>
PRE-REGISTER
£541.99
PRE-REGISTER
Product Description
2x Fans. 2x Fun.
The Dual GeForce RTX™ 3060 Ti MINI Graphics Card is designed for compact gaming builds and the Intel® NUC 9. Features like the Axial-tech fan design, a custom 2-slot thermal solution, and Auto-Extreme Technology make the MINI an obvious choice for those who want an SFF system capable of rivalling the graphics performance of full-sized builds and burly desktops.
Axial-tech Fan Design Better, faster, stronger
Originally the result of R&D efforts for top-end ROG graphics cards, Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure. The enhanced efficiency allows the fan to keep things cool at low RPMs, resulting in less overall system noise and increased component lifespan.
0dB Technology Quiet intelligence
An advanced onboard controller brings fans to a standstill when the GPU core temperature is below 55 Celsius, letting you enjoy light gaming in relative silence. As temps rise, the fans kick back into action.
2-slot Design Sink your heat into this
The Dual MINI features a cooling solution that fits into a 2-slot design less than 20cm in length, making it compatible with small chassis and the Intel® NUC 9 Kits without sacrificing thermal performance. A redesigned shroud, heatsink, and heatpipe layout allows two Axial-tech fans to take advantage of the mesh side panel of the Intel® NUC 9 Extreme Kit and Intel® NUC 9 Pro Kit, while maintaining space for cable management and airflow to the CPU cooler.
Auto−Extreme Technology Precision automated manufacturing
Auto-Extreme Technology is an automated manufacturing process that sets new standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
Protective Backplate That's so metal!
The PCB is reinforced by an aluminum backplate that adds structural rigidity, helping to prevent flex and protect components and trace pathways from damage.
Stainless Steel Bracket Steel yourself
The mounting bracket of the Dual MINI has been beefed up with 304 Stainless Steel that’s harder and more resistant to corrosion.
GPU Tweak II Monitor, tweak, and tune
The ASUS GPU Tweak II utility takes graphics card tuning to the next level. It allows you to tweak critical parameters including GPU core clocks, memory frequency, and voltage settings, with the option to monitor everything in real-time through a customizable on-screen display. Advanced fan control is also included along with many more features to help you get the most out of your graphics card.
XSplit Premium streaming
XSplit offers a premium streaming experience with in-game annotations and other advanced features. Enjoy a free license with the purchase of select ASUS graphics cards. See you online!
wtfast Play lag-free
We've partnered with wtfast to help you to play free from lag, latency issues, and lost packets. With a 6-month subscription to the wtfast Gamers Private Network, you'll enjoy lower ping for a smoother, more fluid online gaming experience. Buy an ASUS graphics card - and don't be left waiting!
Quantumcloud Profit from GPU power
Quantumcloud is a simple and secure service that lets you effortlessly earn extra money by putting your idle GPU to work. Earnings are automatically transferred to your WeChat or PayPal account, and your privacy remains intact because Quantumcloud doesn't collect your personal data. Get started making money today!
144−hour Validation Program “Extensive” may be an understatement
A 144-hour validation program puts cards through a series of stringent tests to ensure compatibility with the latest games.
Subtle Lighting A bit lit
The shroud features a subtle illuminated strip that creates a stylish accent for your build.
Specifications
Specifications
SKU 90YV0FT0-M0NA00
Model ASUS DUAL-RTX3060TI-O8G-MINI
Memory 8GB GDDR6
Condition Status Brand New
MPN 90YV0FT0-M0NA00
HDMI x1 HDMI
Reviews
Related Products
