cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS HS-W1 Headphones Binaural, Wireless, RF 2.4Ghz, Microphone, On Ear, 40mm Driver, Battery Powered
Availability: Out of stock
  • Plug-n-play, 2.4GHz wireless transmission
  • Rotate-to-mute noise-filtering microphone
  • Acoustic tuning with built-in equalizer
  • Long-lasting comfort with enlarged 70mm leather earpads
  • 40mm Driver
£69.99
Product Description
Plug-n-play, 2.4 GHz wireless transmission
No troublesome wires or installation issues. Simple plug-n-play setup allows you to enjoy wireless internet calls and music up to 15-meter range without being tethered to the desk.
Noise-filtering microphone
A noise-filtering microphone ensures quality speech clarity while filtering out ambient background noise every word of yours matters!
Equalized digital audio
A built-in equalizer optimizes voice and music, delivering clear and faithful sound reproduction. Dual 40mm drivers ensure full-range stereo sound.
8-hour rechargeable battery
The HS-W1 provides you up to eight-hours of non-stop conversation. If you are running low on battery, just plug the headset into a USB port without missing a beat.
Long-lasting comfort with enlarged 70mm cushions
An ergonomic design with dual 70mm cushions keep you comfortable by easing pressure points; perfect for relaxed all-day usage.
Rotate-to-mute microphone
The microphone automatically mutes when raised, and immediately picks up a call by rotating the microphone down.
Easy on-ear volume controls
Convenient volume adjustment with control buttons right on the ear pad.
Portable design
Foldable design with a slim durable touring case that fits handbags or suitcases ideal for the business traveler.
Specifications
Specifications
SKU 90-YAHI6130-UA00-
Battery Life Up to 8 Hours
Battery Lithium polymer
Reviews
Related Products
