cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS Lyra AC2200 Tri-Band Mesh WiFi System, App Management, Parental Controls - Single Unit
Availability: Out of stock
  • Tri-band 802.11AC WiFi hubs with MU-MIMO Technology
  • Coverage for Large Homes
  • Commercial-grade Security
  • Advanced parental controls
  • Commercial-Grade Home Network Security
  • Single Unit
£133.48
0% interest for 4 months
Learn More>
£133.48
Product Description
Faster Wi-Fi, for Every Hub
Lyra's tri-band design and smart-antenna technology optimizes the connection between hubs, so each and every hub gets the best possible Wi-Fi signal for maximum stability. Even in the most challenging conditions, Lyra's long-range Wi-Fi performance at the most distant hub is better than competing multi-hub systems.
Protection Against Attacks
Intrusion Prevention System (IPS) blocks all common internet-based attacks.
No Subscription Fee
AiProtection is free for life, with no subscription fees.
Block Access to Malicious Websites
AiProtection uses Trend Micro's official database to identify and block known malicious sites, preventing infection even before you click.
Infection Detection and Blocking
Even if an already-infected device is connected to Lyra, AiProtection prevents any personal data on the device from being compromised.
Pause for Thought
Wi-Fi Pause turns off the internet for a while perfect for when you need some quality family time!
Focus on Your Family
ASUS Lyra lets you keep a watchful eye on your family's internet usage, and adjust the time/application allowance for each family member. State-of-the-art parental controls let you block specific mobile apps and websites, while allowing free access to the rest of the internet.
One App for All
With the ASUS Lyra app you can set up, manage, and diagnose your network even without a PC! To get started, turn on your Lyra hub and connect it using the ASUS Lyra app. Complete your Lyra network details, then click Connect. After about a minute you'll be up and running!
Add extra Lyra hubs, with no hassle!
Adding an extra Lyra hub to your network is easy. Simply follow the on-screen guidance in the ASUS Lyra app: Tap Add Lyra to Current Network; turn on the hub; choose your network; and assign a location. That's all there is to it!
Stay Informed
The Lyra app automatically gives you key status updates and notifications, alerting you when a new device connects, if there's unusual login activity, or when new updates are available.
Safe and Secure
Lyra keeps your network protected at all times, and the Lyra app tells you when threats are blocked or when the security software has been updated.
Specifications
Specifications
SKU 90IG04C0-BU0B20
Model LYRA AC2200
Brand ASUS
MPN 90IG04C0-BU0B20
Reviews
Related Products
