This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16- 15.6-inch Full HD portable USB-powered monitor with a single USB 3.0 cable for power and data transmission
- Worlds slimmest and lightest USB monitor with a sleek and metallic finish
- Auto-rotating display bundled with the ASUS Smart Case a two-way adjustable stand and protective sleeve
Two Screens Are Better Than One
15.6-inch Full HD display with a single USB 3.0 cable for power and data transmission
Worlds slimmest and lightest USB monitors with a metallic finish
The 15.6-inch MB169B+ portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a Full HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality. Whats more, the MB169B+ is backwards compatible with a notebook or desktop PC USB 2.0 port*. *USB 2.0 connection may affect brightness settings and image quality.
With a slim 8.5 mm (0.3-inch) profile and tipping the scales at just 800g (1.76 pounds), the MB169B+ is the worlds slimmest and lightest companion display, ideal for a simple on-the-go dual-monitor setup and mobile presentations.
A durable metallic finish with a fine pattern of concentric circles makes the MB169B+ the perfect complement to your notebook. And for added durability, it comes with a protective carrying case that doubles as an adjustable stand for tabletop use.
The MB169B+ with Auto Rotate (patent-pending) can automatically sense its orientation and switches the display between landscape and portrait based on its position; also, featuring IPS panel ensures a better viewing angle and nearly no color shift promise. These features provide you a more user-friendly scenario.*Auto Rotate functions work when EzLink Utility is properly installed and activated.
The MB169B+ features ASUS EzLink technology that offloads graphics processing from the PC to dedicated hardware in the monitor. As a result, a PC can drive up to five MB169B+ monitors at the same time, regardless of its own graphics capability it just needs sufficient USB ports. EzLink also automatically restores application window positions as a MB169B+ monitor is connected and disconnected, and automatically rotates the image between landscape and portrait modes, as required.
SKU | MB169B+ |
Contrast Ratio | 600:1 |
Response Time | 14 ms |
Compatible Brand | ASUS |
Model | MB169B+ |
Brand | ASUS |
MPN | MB169B+-Feed |
Screen Size | 15.6" |
Manufacturer Warranty | 1 year |
USB Ports | 1 |
