cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS MG248QR 24 inch Full HD Wide Screen Gaming LED Monitor HDMI, Display Port - Pre-Order
Availability: Out of stock
  • Resolution: 1920 x 1080
  • Aspect Ratio: 16:9 (Widescreen)
  • Response Time: 1ms (Gray to Gray)
  • Brightness(Max): 350 cd/
  • ASUS Smart Contrast Ratio (ASCR): 100000000:1
  • Inputs: DVI-D, HDMI and Display Port
  • FreeSync Technology Supported
£299.99
0% interest for 4 months
Learn More>
£299.99
Product Description
Designed for intense, fast-paced games , ASUS MG248QR is a 24" Full HD gaming display with an ultra-fast 1ms response time and blazing 144Hz refresh rate to give you super-smooth gameplay. Gamer-centric features like ASUS GamePlus enhances your in-game experience, while DisplayWidget gives you easy access to various display setting.
Speed, speed, and more speed
Lightning-fast 1ms response time with Extreme Low Motion Blur
ASUS MG248QR is the fastest in its class, boasting a 1ms response time to eliminate smearing and motion blur. This lets you react instantly to what you see onscreen, especially in fast paced games allowing you to take corners like a pro race car driver, or get that headshot like a seasoned pro.
There's also the ASUS Extreme Low Motion Blur Technology to make objects in motion look sharper, so gameplay is more fluid and responsive.
Incredible 144Hz refresh rate
With an astonishing 144Hz refresh rate, fast-moving visuals pose no problem for MG248QR. There's no frustrating lag or motion blur, so you get the upper hand in first person shooters, racers, real-time strategy and sports titles.
Adaptive-Sync technology for smooth gameplay
MG248QR features Adaptive-Sync (Free-Sync) technology - it eliminates screen tearing and choppy frame rates to give you seamless visuals and smooth gameplay.
ASUS-exclusive GamePlus technology
ASUS MG248QR features the ASUS-exclusive GamePlus hotkey to give you in-game enhancements that help you get more out of your game.
  • A crosshair overlay provides four different crosshair options, so you can select the one that best suits the shooter you're currently playing.
  • Activating the display alignment function gives users three alignment lines on all four corners of the monitor to take the guesswork out of multi-display set-ups, so each monitor lines up perfectly.
  • Onscreen timer that can be positioned on the left of the display to keep tracked of elapsed game time.
  • The FPS counter lets you know how smoothly the game is running.
ASUS-exclusive DisplayWidget software
The exclusive ASUS DisplayWidget is intuitive software utility that lets users tweak settings or display properties of ASUS GameVisual, App Sync™, and Ultra-Low Blue Light technologies. Although every adjustment can be done via the OSD and the navigational joystick and buttons, it's easier via DisplayWidget. It makes accessing and using these various settings faster and easier.
Multi-display gaming at its finest
Rich connectivity options, a narrow bezel design
ASUS MG248QR has extensive connectivity options, including dual-link DVI-D, DisplayPort 1.2, and HDMI(v1.4) port, so you can hook it up to a wide array of multimedia devices. It has a super-narrow 1cm bezel ideal for an immersive and panoramic gaming setup.
A smart cable management design feature found on the stand of MG248QR helps you organise and hide cables to keep your gaming area tidy.
Get ready for marathon gaming sessions
Flicker-Free technology
Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimises instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
Ultra-Low Blue Light technology
ASUS Ultra-Low Blue Light technology reduces the amount of harmful blue. You can access and select four different filter settings onscreen easily through the OSD menu or DisplayWidget interface to find one that best suits the content you're viewing.
The MG248QR gaming monitor has undergone stringent performance tests and is certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
Ergonomically designed and wall-mountable
ASUS MG248QR is specially designed for long marathon gaming sessions. Its ergonomically-designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor so you always find your ideal viewing position. It can also be VESA wall-mounted to fit in any limited space.
Specifications
Specifications
SKU MG248QR-Pre-Order
Contrast Ratio 100000000:1
Response Time 1ms (Gray to Gray)
Model MG248QR
Reviews
Related Products
