cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS P3B DLP Portable Projector, 12000mAh Battery, 800 Lumens, Built-in Speaker
Availability: Out of stock
  • Device Type: DLP Projector
  • Brightness: 800 Lumens
  • Resolution: WXGA (1280 x 800)
  • Aspect Ratio: 16:10
  • Ultra Short-Throw Fixed Lens
  • Bulb Life Cycle: Up to 30000 hour(s)
  • Battery Capacity: 12000 mAh
£664.99
0% interest for 4 months
Learn More>
£664.99
Product Description
ASUS P3B Ultra-Short-Throw Battery-Powered Projector is a lightweight and compact projector with a footprint about the size of a CD case, so it fits easily into a briefcase or bag. The brightest battery-powered portable LED projector available, P3B provides crisp WXGA 1280 x 800 resolution images with a maximum brightness of 800 lumens. Its built-in rechargeable battery gives you up to 3 hours of cable-free projection time and also doubles as a 12,000mAh power bank for charging mobile devices.
A ultra-short-throw lens lets the P3B project images measuring from 25 inches (0.45m) to 200 inches (3.4m) at very close range. The P3B is designed to be used anywhere outdoors while camping, in a home theater, or in small meeting rooms.
Bright, Crisp Projections 800 Lumens LED Light Source
ASUS P3B LED Projector features an 800 lumens light output and 100% NTSC color gamut to deliver sharp and vivid WXGA 1280 x 800 visuals. The mercury-free Eco-LED light source has a 30,000-hour lifespan to cut down on bulb-replacement costs.
Ultimate Mobility Compact CD Case-Sized Design
The ultra-slim and compact ASUS P3B tips the scales at just 750g, and has a desktop footprint similar to a CD case (153.5 x 43 x 131.2mm). So it's totally portable and fits perfectly in your bag!
Battery-Powered for Cable-Free Projection
ASUS P3B's built-in rechargeable battery gives you up to 3* hours of cable-free projection time; it means you're free to set up the projector wherever you want without having to worry where the nearest power socket is.
12000mAh Power Bank Design
ASUS P3B can also serve as a power bank to charge your mobile devices even when it is turned off. The powerful 12000mAh capacity means it can charge your mobile devices several times.
Quick, Convenient Setup
Ultra-Short-Throw for Images up to 200 inches
With its ultra-short-throw lens, the ASUS P3B provides projected images measuring from 25 inches to 200 inches at very close distances. This lets you turn any large flat vertical surface into a display, and makes it perfect for presentations in confined spaces
Instant Height Adjustment
ASUS P3B features instant height adjustment thanks to a two-level flip-down stand that can be quickly adjusted to suit the task at hand; this saves you lots of time compared to messing around with fiddly traditional adjustable screw-stands.
Project in a Variety of Ways
ASUS P3B has an optional Wi-Fi adapter for a direct wireless connection to a notebook PC, or Android and iOS devices. This removes the need to carry a video cable solely for presentation use, and allows presentations, documents and multimedia files to be streamed to the P3B wirelessly. The ASUS Wi-Fi Projection software provides advanced Split Screen Control, to allow users to choose two or four split screens from smartphone, tablets or laptops.
Extensive Connectivity
ASUS P3B features HDMI/MHL and VGA ports to provide maximum compatibility with external devices. It lets you conduct presentations even without a PC. It gives you access to documents and multimedia files stored in your microSD card and USB storage device, as well as files saved in its 2GB of storage space.
It can charge MHL-enabled devices while simultaneously projecting their content. Users need not worry about their mobile device running out of charge while in the middle of a presentation.
Specifications
Specifications
SKU 90LJ0070-B10120
Compatible Brand ASUS
Model P3B
Brand ASUS
MPN 90LJ0070-B10120
Reviews
Related Products
