cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS PQ321QE 31.5 inch Widescreen 4K Ultra HD LED Monitor 3840x2160 Response 8ms
Availability: Out of stock
  • 31.5-inch Widescreen 4K Ultra HD Display 3840x2160 Resolution
  • Aspect Ratio 16:9
  • Brightness 350 cd/m²
  • Contrast Ratio 800:1
  • Response Time 8ms
  • Interface: Display Port
£729.99
0% interest for 4 months
Learn More>
£729.99
Product Description
ASUS : In Search of Incredible
ASUS takes its name from Pegasus, the winged horse in Greek mythology that symbolizes wisdom and knowledge. ASUS embodies the strength, purity, and adventurous spirit of this fantastic creature, and soars to new heights with each new product it creates.
An Experience Only 4K Can Deliver: Professional 31.5 4K UHD monitor with 3840 x 2160 resolution
-31.5-inch 4K display with ultra-high definition (UHD) 3840 x 2160 resolution and 140 pixels per inch (PPI) for impeccable visuals
-An anti-glare, LED-backlit IGZO display delivers crisp, precise images with energy efficiency with an ultra-wide viewing angle
-Thinnest 4K UHD monitor ever with DisplayPort and built-in 2W stereo speakers
-Wall-mountable design with tilt, swivel, and height adjustments
Phenomenal 4K visuals
The ASUS PQ321QE True 4K UHD monitor provides stunning visuals with an ultra-high definition 3840 x 2160 resolution. The anti-glare 31.5-inch LED-backlit UHD display has a 16:9 aspect ratio and 140 pixels per inch (PPI) for highly-detailed visuals.
Over 8 million pixels
By doubling the number of horizontal and vertical pixels, the PQ321QE True 4K UHD monitor gives you every bit of detail, far surpassing that of a Full HD monitor. With four times the resolution of Full HD (FHD) and over 8 million pixels, experience larger screen real estate and clarity you have to see to believe.
10-bit color for smoother gradations
The ASUS PQ321QE True 4K UHD monitor is a 10-bit RGB panels that delivers more natural transitions between different hues and offers a more flawless image than ever before.
Premium IGZO display
The ASUS PQ321QE True 4K UHD monitor is built with an anti-glare Indium Gallium Zinc Oxide (IGZO) panel rather than traditional amorphous silicon. The IGZO panel supports much smaller transistors than amorphous silicon, which allows for much smaller pixels and much better detail. Couple with an ultra-wide 176-degree viewing angles on both vertical and horizontal planes, get a pristine image from virtually any angle. Whats more, the IGZO panel supports increased pixel transparency and reduced current leakage for increased energy savings.
Extensive Connectivity
The ASUS PQ321QE True 4K UHD monitor features DisplayPort and built-in 2W stereo speakers, which simplify free space from needing separate speakers for a complete audio visual experience.
Slim Profile with Ergonomic Design
The thinnest 4K monitor available, the ASUS PQ321QE True 4K UHD monitor measure only 35mm at its thickest point, showcasing a modern design fit for anywhere in the home or office.
Specifications
Specifications
SKU PQ321QE
Model PQ321QE
Speakers Built-in speakers
Reviews
Related Products
