cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ProArt Display PA329C 4K HDR Professional Monitor - 32-inch, 4K, HDR-10, VESA DisplayHDR 600, 98% DCI-P3, 100% Adobe RGB, 100% sRGB, 84% Rec. 2020, Hardware Calibration​
Availability: Out of stock
  • 32-inch 4K IPS monitor with an astonishing 100,000,000:1 contrast ratio (ASCR) and a wide, 178° viewing angle
  • VESA DisplayHDR 600 certified HDR-10 presents lifelike experience
  • Exceptional wide color gamut technology provides 98% DCI-P3, 100% Adobe RGB, 100% sRGB and 84% Rec. 2020, color space, pre-calibrated for excellent color accuracy (ΔE < 2)
  • ASUS ProArt™ Calibration technology features a 14-bit look-up table (LUT), uniformity compensation and the ability to save color profiles on the monitor
  • I/O ports: DP over USB-C™ with 60W Power Delivery, DisplayPort, HDMI, USB 3.0 hub
£1,165.99
0% interest for 4 months
Learn More>
£1,165.99
Product Description
ProArt PA329C Professional Monitor Extreme clarity, superior contrast
The ASUS ProArt PA329C 4K UHD HDR professional monitor delivers accurate and brilliant color reproduction and is designed for graphics professionals. PA329C is ideal for high-end video editing, thanks to a wide color gamut of 100% Rec.709 and 100% Adobe RGB for exceptional color fidelity. Up to 600 nits of brightness and VESA DisplayHDR 600 certified provides lifelike experience. ProArt PA329C features USB-C port supports data transfers, DisplayPort and also support 60W power delivery. Advanced ProArt calibration technology and factory pre-calibrated to ensures outstanding color accuracy (E < 2). With Windows- and Mac OS-certified, PA329C is ideal for photographers, colorists, graphic designers, and film editors.
A brighter, more lifelike viewing experience
ProArt PA329C features 32-inch 4K HDR panel with 138 pixels per inch (PPI) to give you four times the pixel density and up to 300% more onscreen space than similarly-sized Full HD displays. VESA DisplayHDR 600 certified HDR-10 enhance the contrast between the brightest and darkest parts of an image and HDR technology delivers exceptional onscreen clarity and detail.
True-to-life Color Wide Color Gamut Technology
ProArt PA329C has a wide color gamut so you have an entire spectrum of colors to play with. Wide color gamut Technology provides 98% DCI-P3, 100% Adobe RGB, 100% sRGB and 84% Rec.2020 color spaces for video editing and production. On top of that, IPS display technology gives you wide viewing angles so there's no color shift, even when you're viewing PA329C from extreme positions. PA329C offers 10-bit color to display over 1.07 billion colors. It uses a 14-bit internal lookup table (LUT) and supports Gamma values of 2.6, 2.4, 2.2, 2.0, and 1.8 to give you natural-looking images, and smoother transitions between hues.
High Color Fidelity for Truly Expressive Hues
Revel in pure, expressive hues thanks to accurate, true-to-life color reproduction. Each ProArt PA329C monitor is factory pre-calibrated to guarantee industry-leading color accuracy (E < 2), so your images are accurately reproduced onscreen, allowing you to see exactly how your work is going to look when it's finished. PA329C also comes with 95% uniformity compensation to guard against brightness and chroma (color) fluctuations on different parts of the screen.
ASUS ProArt Calibration Technology
Whether you're using a desktop, laptop, or Mac, ASUS ProArt Calibration Technology offers color accuracy tuning and uniformity compensation to make things easy when it's time to recalibrate your display's brightness and color consistency.
The USB-C That Does It All
ProArt PA329C gives you unparalleled compatibility with most multimedia devices. It's USB-C, DisplayPort and HDMI ports. The integrated USB-C port supports data transfers, DisplayPort and also support 60W power delivery. ProArt PA329C also serves as a USB hub, meaning that when you connect to it via USB-C (using C to C cable, or C to A cable), and your device gains access to whatever peripherals are connected to the USB ports.
User-Friendly Features ProArt Preset
ProArt Preset can set the color gamut and HDR curves. PA329C provides 9 modes (Standard Mode / sRGB Mode / Adobe RGB Mode / DCI-P3 Mode / DICOM Mode / Rec.709 Mode / HDR_PQ Rec2020 / User Mode1 / User Mode2) and features ASUS Smart HDR technology provides multiple PQ curves (PQ600, PQ Basic and PQ Optimized) to fit your needs, whether you‘re filming or photography, you can quick switch and match your needs easily.
QuickFit Virtual Scale
Save time and work smarter with ASUS QuickFit Virtual Scale. It provides you with an onscreen grid overlay so you can align and preview documents in their actual sizes prior to printing. There's also an intuitive 5-way navigation joystick so you can easily access and switch OSD settings on the onscreen menu.
Protect your eyes with ASUS Eye Care technology Ultra-low Blue Light Monitor
The TÜV Rheinland-certified ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey. ProArt PA329C has undergone stringent performance tests and has been certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
Flicker-free Technology
It's time to say goodbye to those tired, strained eyes. ProArt PA329C features TÜV Rheinland-certified ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
Ergonomic Design
With ProArt PA329C, a comfortable viewing position is always within reach thanks to its slim profile and ergonomically-designed stand with tilt, swivel, pivot, and height adjustments. It's versatile too, the Auto Rotation function adjusts the orientation of the content when you pivot the display into Portrait mode - handy when working with websites or longer documents.
Specifications
Specifications
SKU PA329C
Contrast Ratio 1000:1
Response Time 5 ms
Model PA329C
Brand ASUS
Condition Status Brand New
MPN PA329C
Screen Size 32 in
Maximum Resolution 3840 x 2160
Manufacturer Warranty 1 year
Features Flat Screen, Headphone Jack
Reviews
Related Products
