cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Chakram RGB wireless gaming mouse with Qi charging
Availability: Out of stock
    • Tri-mode connectivity includes dual-wireless 2.4GHz and Bluetooth(BLE), plus wired USB
    • Industry-leading 16000 dpi, 400 ips optical sensor, plus 1000 Hz polling rate support in 2.4GHz and wired mode
    • Programmable, removable joystick allows personalized settings and superior in-game control
    • Fast charge for 15 minutes by wire for up to 12 hours of gameplay, or use Qi technology for wireless charging
    • Screw-less magnetic buttons and cover, ROG exclusive push-fit switch socket design and customizable badge for effortless DIY
    • Pivoted button mechanism offers rapid response and accurate performance with a clean, tactile feel
    • DPI On-The-Scroll manipulation for effortless accuracy adjustments
    • Armoury II interface enables intuitive adjustment of joystick, button, performance or light settings
£149.99
0% interest for 4 months
Learn More>
£149.99
Product Description
ROG Chakram's built-in joystick means you can dispense with a gamepad, keeping your hands on the mouse and keyboard. It can be configured to perform in one of two distinct modes - analog or digital - to fit different needs. You can even choose between a long or a short stick, both supplied, or remove the stick completely.
Analog Mode
When you set ROG Chakram's joystick to Analog Mode it simulates a real analog stick or joypad thumb stick, making it ideal for flight sims and racing game, empowering you to climb, dive , drift, pan the view - or any analog control.
Digital Mode
For first-person-shooter (FPS) or battle-royale arena commands, ROG Chakram's joystick can go digital, providing four programmable directions. Just push to reload, switch weapons, tilt, talk, summon a map, scroll web pages or practically any action imaginable - in games or beyond.
Customizable Joystick
We've included both a long and a short joystick to match different hand shapes and play styles. For times when the stick isn't needed, then whip it off and fit the included socket covers for a flush finish.
Ultra Performance
ROG Chakram is equipped with a high-end optical gaming sensor to deliver the accuracy and speed you need. Its 100 to 16,000 dpi sensor tracks movements flawlessly up to an outstanding speed of 400 inches per second (IPS) at up to 40 g acceleration. You'll also enjoy lag-free responsiveness with a 1,000 Hz polling rate in both 2.4GHz and wired mode for ultrasmooth gaming experiences.
Aura Lighting
Take style to the next level with ASUS Aura Sync RGB lighting. Fully customize your mouse using an endless spectrum of colors and a range of dynamic lighting effects. All illuminations can be synced with an ever-growing portfolio of Aura Sync-capable hardware to create a truly personalized gaming den.
Specifications
Specifications
SKU 90MP01K0-BMUA00
Hardware Connectivity USB
Model ROG Chakram
Brand ASUS
MPN 90MP01K0-BMUA00
Reviews
Related Products
