cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Harrier GT300 Optical Gaming Mouse with optical sensor & Omron switches
Availability: Out of stock
  • High-quality Pixart PMW3325 optical sensor and Omron switches
  • 2-way DPI switch for more accurate sniping or faster cursor movement
  • Onboard memory for saving up one profile settings
  • ASUS Aura RGB lighting with 16.8 million colors and four preset effects
  • Simple, intuitive software interface for easy customisation
£34.99
£34.99
Product Description
High-Quality Optical Sensor And Omron Switches
The ROG Harrier GT300 Gaming Mouse delivers unmatched precision and accuracy. Featuring a Pixart PMW3325 optical sensor with a sensitivity range of 200 to 5000 DPI, the ROG Harrier GT300 offers true 1:1 tracking for high-precision, no acceleration cursor movement. The ROG Harrier GT300 utilises durable, high-quality Omron® switches that provide a superior click feel and response.
Two-Way DPI Switch
2-way DPI switch for more accurate sniping or faster cursor movement.
Braided Cable With USB Gold Plating
ROG Harrier GT300 provides extreme protection and comfort.
Ergonomically-Designed For Comfortable Gaming Sessions
Whatever grip type you use, the ergonomically-designed ROG Harrier GT300 sits comfortably in your hand, making it ideal for extended marathon gaming sessions.
Simple, Intuitive Software Interface
The simple, intuitive software interface of the ROG Harrier GT300 lets you easily tweak all parameters, including ASUS Aura RGB settings, DPI levels and button functions.
You can even access more advanced settings such as angle-snapping, lift height cut-off, double-click speeds and USB polling rates. A test arena provides a virtual proving ground, where youre free to experiment with your settings so youll always be ready for battle!
Asus AURA RGB
It also features fully customisable ASUS Aura RGB lighting with 16.8 million colours and four pre-set effects.
Specifications
Specifications
SKU 90XB03V0-BMU010
Model GT300
Brand ASUS
MPN 90XB03V0-BMU010
Reviews
Related Products
