cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Keris Wireless Lightweight FPS Wireless Gaming Mouse, 16,000 dpi sensor
  • Tri-mode connectivity with dual-wireless 2.4 GHz and Bluetooth® LE, plus wired USB
  • Specially tuned ROG 16,000 dpi, 400 ips optical sensor and 1000 Hz polling rate
  • Optimized for FPS games, ergonomic design is based on input from esports pros
  • ROG exclusive push-fit switch socket to vary click force and extend the lifespan of the mouse
  • ROG Micro Switches for consistent click force and 70-million-click lifespan
  • Up to 78 hours of battery life, or 56 hours with RGB lighting on
  • Pre-register your Product to find out when the device will be available for pre-order/order
£89.99
PRE-REGISTER
£89.99
PRE-REGISTER
Product Description
MADE FOR PROS
ROG Keris Wireless is a lightweight, 79-gram FPS wireless gaming mouse featuring tri-mode connectivity — wired, 2.4 GHz RF, or Bluetooth® LE — and a specially tuned ROG 16,000 dpi sensor. It also features exclusive push-fit switch sockets with ROG Micro Switches, left and right PBT polymer buttons, swappable side buttons, ROG Omni Mouse feet, ROG Paracord and Aura Sync RGB lighting.
TRI-MODE CONNECTIVITY
ROG Keris Wireless can be connected in one of three ways — via ultrafast 2.4 GHz, energy-efficient Bluetooth® LE, or wired USB. Use 2.4 GHz wireless for gaming, and switch to Bluetooth LE for daily tasks.
ULTIMATE ACCURACY
Every strike is critical. At the heart of ROG Keris Wireless is an optical sensor that’s been specially-tuned by ROG, giving you unerring accuracy and precision to take down the competition.
  • 16,000 DPI
  • 40G Max Acceleration
  • 400 IPS Max Speed
ERGONOMIC DESIGN
ROG enlisted the help of professional gamers when designing Keris Wireless, using their feedback to create a gaming mouse with exceptional ergonomics. The resulting fine-tuned curves are a perfect fit for any hand, making it the ideal mouse for marathon gaming.
ROG MICRO SWITCH
Keris Wireless features the new ROG Micro Switch with 70-million-click lifespan and a gold-plated electro-junction to improve durability and extend life. Strict ROG manufacturing standards ensure each individual switch is inspected and sorted, with both left and right switches paired to keep force deviation within +/- 5 gram-force for a consistent click feel.
  • 70M Click Lifespan
  • +/- 5 GF L/R Switch Force Deviation
  • Gold-Plated Electro Junction
EXCLUSIVE PUSH-FIT SWITCH SOCKET
Exclusive push-fit switch sockets make it easy to drop in new switches — so you can tailor operating force and feedback to preference, or replace worn or broken switches to extend lifespan.
LIGHTWEIGHT INTERNAL STRUCTURE
An internal honeycomb-like structure provides structural support while keeping weight down to just 79 grams.
PBT L/R BUTTONS
The left and right PBT buttons have a durable nonslip surface that resists wear or shine, ensuring a consistent feel.
ROG PARACORD
ROG Keris Wireless includes the improved ROG Paracord. Extremely flexible and lightweight, it’s designed to minimize snags and maximize movement. The raised port design also provides space between the cable and tabletop or mousepad surface, minimizing cable drag and noise.
ADVANCED POWER SOLUTION
USB Type-C® fast charging provides up to 12 hours of gameplay from just a 15-minute charge. Play wirelessly for up to 78 hours with lights off, or up to 56 hours with RGB lighting on*.
*Battery life test conducted in 2.4 GHz mode.
AURA RGB LIGHTING & ARMOURY CRATE
ROG Aura RGB lighting is integrated into the logo and the scroll wheel of ROG Keris Wireless. Lighting can be customized with a near-endless spectrum of colors and a range of dynamic effects. In addition, up to three profiles can be stored onboard, so your preferences travel with you. Armoury Crate lets you easily tune Keris Wireless to suit your gameplay — adjust performance and surface calibration settings, program and map buttons, customize lighting effects, and more.
Specifications
Specifications
SKU 90MP0230-B0UA00
Model ROG Strix Impact II
Brand ASUS
Condition Status Brand New
MPN 90MP01P0-BMUA00
Warranty 1 Year
Features Tri-mode connectivity with dual-wireless 2.4 GHz and Bluetooth LE, plus wired USB, Up to 78 hours of battery life, or 56 hours with RGB lighting on
Reviews
Related Products
