This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16Illuminate Every Journey
ROG Ranger BP3703 Gaming Backpack is the first ROG backpack to incorporate Aura RGB effects and loads of travel-friendly features. The modular design makes it easy to detach your essentials when needed, while water–repellent materials, rain cover and security features keep you protected on the go. With 20L capacity that's big enough for a 17'' laptop and essential stuff, BP3703 is all you need to transport your gaming gear and travel kit to every tournament.
Aura RGB for
All the Adventures
Ranger BP3703's bold ROG logo and slash illuminate to seven preset effects and a choice of eight striking colors, with brightness that reacts automatically to the ambient lighting conditions – all easily managed by an IPX4 splash-proof intuitive one-touch controller. There's even a bright-white internal light strip to make it easy to see and find your stuff, even in the dark. Just attach your own power bank*, and light up anywhere.
Internal Light Strip
A single tap on the one-touch controller illuminates an internal light strip, making it easier to see and organize your stuff – even in the dark.
Travel Light, Travel Secure
The modular front compartment is easily detachable and has its own shoulder strap, so you can use it to carry essentials when you need to travel light – like having two bags in one. This go-anywhere messenger bag also has a clever RFID-blocking pocket inside to reduce the risk of falling victim to skimming scams, adding security to everyday convenience.
Pack and Travel, Your Way
Your bag shouldn't add to the stress of travel, so Ranger BP3703 is made for fast packing and unpacking, easy transport and flexible travel.
Suitcase-Style Opening
Almost the whole front panel unzips for fast packing and easy access to the main compartment.
Internal Detachable Pouch
A go-anywhere pocket stores vital gear, ready for you to grab and go.
Luggage Strap
An integrated fabric brace can be used to secure BP3703 to an extending suitcase handle.
All Dry, All Secure
Worry less about inclement weather or opportunist theft, as BP3703 is loaded with features to keep your stuff safe, secure and dry – every day and everywhere.
Reflective Rain Cover
A full reflective rain cover is included, stowed in a dedicated pocket at the base.
Water-Repellent Protection
Strong water-repellent 1680D polyester exterior and zips brush off everyday showers and light spray.
Anti-Theft Zip
A carabiner-style clip secures the zip ends, hampering would-be thieves.
Hidden Backrest Pocket
Items such as phone and passport can be concealed in the backrest, so they're safe but accessible.
Your Gear,
Organized Your Way
Ranger BP3703 helps organize your pack and trip, with two separate compartments and a modular messenger bag. The first partition has numerous smaller pockets inside to prevent items scratching each other, plus a detachable pouch to fit your needs. The second compartment is a large, padded slot for an up to 17” laptop. The backpack even has a cable-passthrough slot, allowing you to game and charge on the go – directly from your own power bank inside.
Carry in Breathable
Comfort
Ranger BP3703 is designed to keep you comfortable. The shoulder straps are generously padded, and easily adjusted to provide a snug, secure fit. The back panel is covered in a fine-weave air mesh to provide better airflow and keep you feeling fresh for longer.
SKU | 90XB05X0-BBP010 |
Model | ASUS ROG Ranger BP3703 |
Brand | ASUS |
Condition Status | Brand New |
MPN | 90XB05X0-BBP010 |
