cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Strix Scope RX optical Mechanical RGB gaming keyboard for FPS gamers, with ROG Optical Mechanical Switches, All-around Aura Sync RGB illumination, IP56 water resistance, USB 2.0 passthrough, and alloy top plate
Availability: Out of stock
  • ROG RX Optical Mechanical Switches: Enjoy consistent, wobble-free keystrokes with 1 ms response and 100-million-keystroke lifespan
  • Light it up with ROG: Per-key RGB LEDs with central lighting for all-round illumination, backlit ROG logo, and customizable light effects
  • Built to last: Alloy top cover and IP56 water and dust resistance help ensure long lifespan
  • USB 2.0 passthrough: Full-function port for device charging and external storage
  • FPS-ready: Extended Ctrl key for ‘Crouch’ and other commands
  • Stealth key: Tap to hide all apps and mute audio for instant privacy
  • Quick-toggle switch: Instantly shift between function and media key input
  • Macros, management, and onboard memory: Map multi-key commands, adjust settings via Armoury Crate, and store up to five profiles on the onboard memory
£124.99
0% interest for 4 months
Learn More>
£124.99
Product Description
ROG STRIX SCOPE RX
ROG RX Optical Mechanical Switches: Enjoy consistent, wobble-free keystrokes with 1 ms response & 100-million-keystroke lifespan
Light it up with ROG: Per-key RGB LEDs with central lighting for all-round illumination, backlit ROG logo, & customizable light effects
Built to last: Alloy top cover & IP56 water & dust resistance help ensure long lifespan
USB 2.0 passthrough: Full-function port for device charging & external storage
FPS-ready: Extended Ctrl key for ‘Crouch’ & other commands
Stealth key: Tap to hide all apps & mute audio for instant privacy
Quick-toggle switch: Instantly shift between function & media key input
Macros, management, & onboard memory: Map multi-key commands, adjust settings via Armoury Crate, & store up to five profiles on the onboard memory
PLAY AT THE SPEED OF LIGHT
Take on all comers with ROG Strix Scope RX, the first mechanical RGB gaming keyboard featuring exclusive ROG RX Red Optical Mechanical Switches. These switches provide a 100-million-keystroke lifespan and offer consistent linear keystrokes with immediate response. In addition, each switch has a central RGB LED to give every key all-round lighting. Strix Scope RX also offers IP56 water and dust resistance, an alloy top cover, and USB 2.0 passthrough. Like all Strix Scope series gaming keyboards, it has a wider Ctrl key and a Stealth key for FPS gamers. Go confidently into battle with ROG Strix Scope RX.
BUILT TO LAST
ROG Strix Scope RX offers industry-leading IP56 dust and water resistance, ensuring it’s well-protected from spills and dust. It also has a durable aluminum alloy top plate that provides structural rigidity to give you long-lasting and reliable performance.
CRAFTED FOR FPS GAMERS
After studying the play style of FPS gamers, the ROG R&D team created Xccurate Design: a Ctrl key that’s twice as wide as usual. In the heat of battle, the larger size makes it easy to quickly find and hit.
INSTANT PRIVACY
Marked with an iconic cloaked-figure keycap, the Stealth key instantly hides all apps and mutes all audio, assuring instant privacy, whenever you need it. A simple tap engages it, and another tap brings apps and audio back up, as they were.
USB 2.0 PASSTHROUGH
Convenient USB 2.0 passthrough lets you plug in a mouse or flash drive, or charge mobile devices.
READY FOR WORK OR PLAY
The Quick-Toggle Switch prepares ROG Strix Scope RX for gaming or the daily grind, toggling the top row between Media or Function (Fn) key input – so it's easy to switch modes for work or play. The keyboard is topped with an aluminum faceplate for everyday resilience, and finished with a striking slash aesthetic for a little touch of style.
AURA SYNC
Vibrant per-key backlighting illuminates Strix Scope from top to bottom and edge to edge. Powered by Aura Sync, the entire color spectrum and a range of dynamic lighting effects are at your command for you to create a keyboard that's uniquely yours. The lighting is easily synced with the extensive Aura ecosystem to create a gaming environment that really shines.
Specifications
Specifications
SKU 90MP0240-BKEA00
Model ASUS ROG STRIX SCOPE
Condition Status Brand New
MPN 90MP0240-BKEA00
Reviews
Related Products
