This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16ASUS TUF Gaming GT301 ATX mid-tower compact case with tempered glass side panel, honeycomb front panel, 120mm AURA Addressable RGB fan, headphone hanger and 360mm radiator support.
COMBAT-READY PERFORMANCE
A perforated honeycomb design spread across the front and top of the chassis aids airflow and also lends some style to an already unique aesthetic
LIGHT IT UP
Fitted addressable RGB-enabled fans enable to work with the Aura-supported motherboards.
With exclusive ASUS Aura Sync lighting technology, TUF Gaming GT301 provides ambient lighting that can be synchronized with other Aura Sync-enabled components.
SHOW YOUR TUF PERSONALITY
The Customized headset hook which can be hanged on both sides
OUTSTANDING COMPACT GAMING
TUF Gaming GT301 is a feature-packed case and made for the masses, the optimized compact case supports up to 4 x 2.5” SSDs, 2 x 3.5” HDDs and quick removal dust filter in front, top and bottom
SKU | 90DC0040-B49000 |
Compatible Brand | ASUS |
Model | ASUS TUF Gaming GT301 |
Condition Status | Brand New |
MPN | 90DC0040-B49000 |
