cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS TUF Gaming GT501 Case with Tempered-Glass Side Panel, 120 mm RGB Fan
  • Designed to be noticed: Metal front panel with custom TUF Gaming spatter pattern, and 4mm-thick, smoked, tempered-glass side panel to showcase your build’s internals.
  • Mobile battle station: Ergonomic, woven-cotton carry handles enable easy and safe transport up to 30Kg.
  • Efficient cooling: Equipped with three 120mm Aura Sync RGB-illuminated fans and one 140mm rear PWM fan, plus up to seven fan-mounting points for targeted airflow.
  • Space reserved for both front- and top-mounted 360mm water-cooling radiators plus a 140mm radiator at the rear.
  • Perfect for TUF Gaming motherboards: Fan and cable placement optimized for TUF Gaming gear, and ready for perfect cooling control via our Fan Xpert 4 software.
  • Pre-register your Product to find out when the device will be available for pre-order/order
£154.99
0% interest for 4 months
Learn More>
PRE-REGISTER
£154.99
PRE-REGISTER
Product Description
Specifications
Specifications
SKU 90DC0012-B49000
Compatible Brand ASUS
Model TUF Gaming GT501
Brand ASUS
Condition Status Brand New
MPN 90DC0012-B49000
Warranty 1 Year
Features ATX Mid Tower, ATX/micro ATX/Mini ITX/EATX, 4 x 2.5/3.5, 3x 2.5", Front: 3x 120mm AURA RGB (1200RPM), Rear: 1x 140 PWM, 10.5 kg, Black
Reviews
Related Products
