cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS TUF Gaming GT501VC Tower Case Supports up to EATX With Metal Front Panel
    • Designed to be noticed: Metal front panel with custom TUF Gaming spatter pattern, and 4mm-thick, smoked, tempered-glass side panel to showcase your build’s internals.
    • Space reserved: For both front- and top-mounted 360mm water-cooling radiators plus a 140mm radiator at the rear.
    • Show off your build: Its shell is made of SGCC steel with durable fluorocarbon paint that provides stable protection for the components and the smoked style of the tempered glass inherits the restrained style of TUF Gaming GT501, allow gamers to better showcase their personalized build.
    • Pre-register your Product to find out when the device will be available for pre-order/order
£109.99
0% interest for 4 months
Learn More>
PRE-REGISTER
£109.99
PRE-REGISTER
Product Description
Show Your TUF Personality
With a full-height, smoked-glass side panel, GT501VC lets you show off your build from top to bottom €“ so your components, customizations and Aura illuminations are all clearly visible. This panel is tempered for strength, and hinged at the bottom for opening ease.
Cooling Fan Design
It's easy to upgrade cooling when you need, with up to seven mounting points for the installation of fans.
Radiator Support
The case has space reserved both front- and top-mounted 360mm water-cooling radiators plus a 140mm radiator at the rear for future-proof chills. The interior is also thoughtfully laid out with lots of user-friendly design touches, providing a firm foundation for DIY builds that are easy to keep clean, tidy and cool.
Easy PC DIY
GT501VC makes PC DIY easier than ever. Integrated cable-management ensures neatness, while pre-installed physical supports for the motherboard eliminates additional costs and mean you're ready to build from the get-go. It all adds up to design with you in mind for an unrivaled PC-building experience.
Keep Your Build Like New
Removable dust filters effectively prevent airborne particulates from entering TUF Gaming GT501VC, keeping your system's internals looking as good as new for longer. The top and front filter are magnetic for a tight seal, and quick removal and cleaning, while the lower dust-trap is easily slid in and out to enable fast maintenance.
Specifications
Specifications
SKU 90DC00A2-B09000
Compatible Brand ASUS
Model ASUS TUF Gaming GT501VC
Condition Status Brand New
MPN 90DC00A2-B09000
Warranty 1 Year
Features TUF Gaming GT501VC, 3x 2.5", 4x 2.5/3.5", USB 3.1, 3.5mm, ATX/micro ATX/Mini ITX/EATX, 251x545x552 mm, Black
Reviews
Related Products
