cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS VP28UQG 28 inch 4K Ultra HD Wide Screen Gaming LED Monitor HDMI, Display Port - Pre-Order
Availability: Out of stock
  • Resolution: 3840 x 2160
  • Aspect Ratio: 16:9 (Widescreen)
  • Response Time: 1ms (Gray to Gray)
  • Brightness: 300 cd/
  • Contrast Ratio: 1000:1
  • ASUS Smart Contrast Ratio (ASCR): 100000000:1
  • Inputs: HDMI and Display Port
  • FreeSync Technology Supported
£329.99
0% interest for 4 months
Learn More>
£329.99
Product Description
The ASUS VP28UQG gaming display is built for victory in the professional gaming arena. With its 4K UHD panel and 1ms response time, it blurs the line between what's virtual and what's real to draw you into truly immersive gaming worlds. It even includes gamer-centric features like ASUS GamePlus technologies to take your gaming experience to a whole new level.
A 28-inch 4K UHD display
for highly-detailed
visuals and more onscreen space
With its 28-inch 4K UHD display, ASUS VP28UQG gives you stunning 3840 x 2160 resolution visuals with a pixel density of 157PPI for incredible photo-realistic visuals and sharp, crisp text. The VP28UQG gives you four times the pixels of similar-sized Full HD 1080p displays so you get more detailed images when playing games or watching movies, as well as more onscreen desktop space for your various work windows. VP28UQG draws you into immersive virtual worlds, with greatly-textured elements and terrain maps that boast impressive levels of detail.
  • Conventional 28-inch 1920 x 1080 monitor
    Shows less detail and spacing with less room for work bars on the side.
    Images are relatively blurrier.
  • VP28UQG 28-inch 3840 x 2160 monitor
    See more details and 3 times more onscreen space for working bar on the side. Images are much more crisp and detailed.
Lightning-fast 1ms rapid response time
Even with today's fastest games, ASUS VP28UQG eliminates smearing and motion blur thanks to a 1ms response time the fastest in its class. This astonishing visual performance lets you react instinctively to what you see onscreen, so you can take corners like a pro race car driver, or take an enemy out with a headshot as he peeks around cover. In addition, Adaptive-Sync/FreeSync™ eliminates screen tearing and choppy frame rates for even more seamlessly smooth gameplay.
Robust connectivity
Whether you're playing games or streaming videos, ASUS VP28UQG gives you smooth 4K UHD content playback, thanks to a 60Hz refresh rate and native 4K UHD support via DisplayPort 1.2, HDMI(v 2.0).
Gamer-centric features
ASUS-exclusive GamePlus technology
ASUS VP28UQG features the ASUS-exclusive GamePlus to give you in-game enhancements that help you get more out of your game. These tools allow gamers to practice and improve on their gaming skills.
  • Crosshair
    You can choose between four persistent crosshairs and fine tune their position, ensuring pinpoint accuracy in first-person shooters. Enjoy perfect aim even when the game doesn't provide its own crosshair or sights.
  • Timer
    The on-screen timer keeps tabs on recurring drops, respawns, and other time-based events. And you can move it anywhere on the screen with the navigation joystick to make sure it doesn't interfere with the in-game HUD.
  • FPS counter
    it shows the rate at which frames are being drawn by the display. This information can be used to evaluate the performance impact of different graphics settings and system configurations, so you can fine-tune the balance between in-game visuals and frame rates.
  • Display Alignment
    When activated, three lines appear on all four sides of the VP28UQG in order to eliminate any guesswork in lining up each monitor in your multi-display set-up perfectly.
Get ready for marathon gaming sessions
Ultra-Low Blue Light technology
ASUS Ultra-Low Blue Light technology reduces the amount of harmful blue light emitted by ASUS VP28UQG. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand.
The VP28UQG gaming monitor has undergone stringent performance tests and is certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
Flicker-Free technology
Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
Specifications
Specifications
SKU VP28UQG-Pre-Order
Contrast Ratio 1000:1
Response Time 1ms (Gray to Gray)
Model VP28UQG
Reviews
Related Products
