cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ZenBeam E1 Pocket LED Projector 150 Lumens Built-in 6000mAh Battery WVGA (854x480) Up to 5-Hour Projection Power Bank Auto Keystone Correction HDMI/MHL
Availability: Out of stock
    • 150-lumen output with WVGA (854x480) resolution that automatically accepts FullHD 1080p sources
    • Projects visuals ranging up to 120 inches
    • Built-in 6,000mAh battery provides up to 5 hours of projection time and doubles as a power bank for mobile devices.
    • Project content from mobile devices, media streamers, and gaming consoles via HDMI/MHL
    • Quick, easy setup with instant on/off capabilities, auto keystone correction and ASUS SonicMaster speaker
£229.99
0% interest for 4 months
Learn More>
£229.99
Product Description
ASUS ZENBEAM E1 WVGA DLP PORTABLE PROJECTOR
ASUS ZenBeam E1 is a TV-sized screen in your pocket that's able to deliver up to 120-inch-diagonal projections. Designed with compatibility in mind, this palm-sized projector has an HDMI/MHL input to connect to everything including PCs, smartphones and media streamers. ASUS ZenBeam E1 includes a built-in 6000mAh rechargeable battery that delivers up to 5 hours of projection time when you're on the go, and doubles as a power bank for your mobile devices.
KEY FEATURES:
AWARD-WINNING ZEN-INSPIRED DESIGN
Catering to the stylish on-the-go traveler, ASUS ZenBeam E1 weighs only 307g and has ultra-compact dimensions of 83 x 29 x 110mm. The Zen-inspired design, with its understated aesthetic and spun-metal finish on the lens cap, recently helped ZenBeam E1 win both an iF Product Design Award and a Red Dot Design Award, which are prestigious global awards celebrating design excellence.
UP TO 120-INCH IMAGES FOR TRUE-TO-LIFE ENTERTAINMENT
At the heart of ASUS ZenBeam E1 is its bright 150 lumen Eco-LED light source with 30,000-hour lifespan and 100% NTSC color gamut. DLP® IntelliBright™ technology efficiently boosts brightness and contrast by up to 30%, while lowering power consumption by up to 50%.
Accepting up to Full HD 1080p sources, the ASUS Zenbeam E1 automatically scales to its native WVGA (854 x 480) resolution, while preserving visual clarity and integrity to deliver projections sized from 15 inches up to 120 inches, even at short distances.
PERFECT FOR MOBILE DEVICES, GAME CONSOLES, COMPUTE STICKS AND MEDIA STREAMERS
The HDMI/MHL* port on the ASUS ZenBeam E1 easily connects to game consoles and MHL-enabled mobile devices and can even charge your mobile device while simultaneously projecting content. The ASUS ZenBeam E1 is also compatible with a variety of media streamers even with compute sticks like chromebit, vivosticks so you can enjoy movies and TV series.
AUTO KEYSTONE CORRECTION
Auto keystone correction automatically eliminates trapezoidal images that can result from angled projection, achieving a perfect rectangle every time.
UP TO 5 HOURS OF CABLE-FREE PROJECTION
ASUS ZenBeam E1 has a built-in rechargeable battery that gives you up to 5 hours of cable-free projection time. It also doubles as a power bank to charge mobile devices on the go.
BUILT-IN SPEAKER WITH ASUS SONICMASTER TECHNOLOGY
ASUS ZenBeam E1 provides exceptional sound through its exclusive ASUS SonicMaster-enhanced speaker for a truly cinematic audiovisual experience.
FAST AND EASY SETUP
Setting up ASUS ZenBeam E1 is easy. Just connect a source, turn on ASUS ZenBeam E1 and adjust focus using the focus ring for up to 120-inch projections when placed just 3.7m from any flat surface.
WHAT'S IN THE BOX:
ASUS ZenBeam E1 Projector
Carrying Bag
HDMI cable
Power Adapter
Quick Start Guide
Warranty card
Specifications
Specifications
SKU 90LJ0080-B00520
Contrast Ratio 16:9
Model ASUS ZenBeam E1
Brand ASUS
Condition Status Brand New
MPN 90LJ0080-B00520
Maximum Resolution 854 x 480
Manufacturer Warranty 1 year
HDMI Yes
Features Theater Mode, built-in smartphone charger, flashlight mode, ASUS SonicMaster
Reviews
Related Products
