cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS TUF Gaming GT301 ATX mid-tower compact case with tempered glass side panel, honeycomb front panel, 120mm AURA Addressable RGB fan, headphone hanger and 360mm radiator support
    • Stylishly design: Perforated honeycomb front panel to aid airflow and features a tempered-glass side panel to showcase your build’s internals in the compact case.Efficient cooling: Equipped with three 120mm Aura Sync addressable RGB-illuminated fans and one 120mm rear fan, plus up to six fan-mounting points for targeted airflow.
    • Space reserved for 280/360mm water-cooling radiators in front and 120mm at rear
    • Integrated 6 ports Aura Sync addressable-RGB controller hub and a dedicated front panel control button to create a stunning lighting effect
    • Extensive storage options: up to 2 HDD (trays included) and 6x SDD (2x dedicated bracket included, one is on the power supply shroud) mounting locations
    • Combat-ready: Customized headphone hook which can be hanged on both sides
    • Pre-register your Product to find out when the device will be available for pre-order/order
£94.99
PRE-REGISTER
£94.99
PRE-REGISTER
Product Description
ASUS TUF Gaming GT301 ATX mid-tower compact case with tempered glass side panel, honeycomb front panel, 120mm AURA Addressable RGB fan, headphone hanger and 360mm radiator support.
COMBAT-READY PERFORMANCE
A perforated honeycomb design spread across the front and top of the chassis aids airflow and also lends some style to an already unique aesthetic
LIGHT IT UP
Fitted addressable RGB-enabled fans enable to work with the Aura-supported motherboards.
With exclusive ASUS Aura Sync lighting technology, TUF Gaming GT301 provides ambient lighting that can be synchronized with other Aura Sync-enabled components.
SHOW YOUR TUF PERSONALITY
The Customized headset hook which can be hanged on both sides
OUTSTANDING COMPACT GAMING
TUF Gaming GT301 is a feature-packed case and made for the masses, the optimized compact case supports up to 4 x 2.5” SSDs, 2 x 3.5” HDDs and quick removal dust filter in front, top and bottom
Specifications
Specifications
SKU 90DC0040-B49000
Compatible Brand ASUS
Model ASUS TUF Gaming GT301
Condition Status Brand New
MPN 90DC0040-B49000
Warranty 1 Year
Features ATX/micro ATX/Mini ITX, ATX mid tower, 426 x 214 x 482mm, 7.2kg
Reviews
Related Products
