cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Falchion Wireless Mechanical Gaming Keyboard with 68 Keys, Cherry MX
Availability: Out of stock
  • Compact 65% layout masterfully incorporates arrow and navigation keys, in a 60% keyboard frame
  • Interactive touch panel makes it easy to adjust and customize controls
  • Dual-mode connectivity via wired USB and 1 ms at 2.4 GHz RF, and up to 450 hours of battery life* offer stable, long-lasting performance (*with RGB lighting off)
  • Durable and long-lasting ROG PBT doubleshot keycaps
  • Innovative keyboard cover case provides on-the-go protection
  • First ROG keyboard to feature wireless Aura Sync with per-key RGB lighting
£149.99
0% interest for 4 months
Learn More>
£149.99
Product Description
COMPACT, WITHOUT COMPROMISE
ROG Falchion is a 65% form-factor wireless mechanical keyboard designed to change the way you play. It has an interactive touch panel and innovative two-way cover case, and it’s the first ROG keyboard with wireless Aura Sync RGB lighting. The keys feature durable ROG polybutylene terephthalate (PBT) doubleshot keycaps and German-made Cherry MX RGB mechanical switches for precise, tactile keystrokes. ROG Falchion utilizes a gaming-grade 2.4 GHz RF connection for 1 ms report rate and offers up to 450 hours of battery life on a single charge.
PRODUCT VIDEO
Compact, without compromise. It’s time to get a closer look at ROG Falchion.
65% FORM FACTOR FOR A MINIMALIST SETUP
The ROG team aimed to provide a compact keyboard without compromise, masterfully incorporating arrow and navigation keys into a 65% keyboard layout. And at just 306 mm in length, ROG Falchion is almost the same size as a 60% keyboard. It gives you all the functions of a normal keyboard without taking up much desktop space.
DUAL-MODE CONNECTIVITY AND
UP TO 450-HOUR BATTERY LIFE
A near-zero latency 2.4 GHz RF connection and up to 450 hours of battery life* deliver the stability and longevity gamers need for the ultimate gaming experiences. It can also be used in wired USB mode.
DURABLE PBT
DOUBLESHOT KEYCAPS
ROG PBT Doubleshot Keycaps provide a unique and premium feel, as well as offer long-lasting durability. Key design has been optimized with mid-height keycaps and a shorter stem to reduce key wobble and provide a more comfortable user experience. The precise double-shot molding process results in translucent keycaps* that feature seamless ROG script for a unique look, giving ROG Falchion consistent lighting and a look that’s unmistakably ROG.
WIRELESS AURA SYNC PER-KEY RGB LIGHTING
ROG Falchion is the first keyboard to feature wireless Aura Sync RGB lighting. With Aura Sync RGB, the entire color spectrum and a range of dynamic lighting effects are at your command, so you can create a keyboard that's uniquely yours. Customize and shine in your own way, wirelessly.
Specifications
Specifications
SKU 90MP01Y0-BKEA00
Compatible Brand ASUS
Model Asus ROG Falchion
Condition Status Brand New
MPN 90MP01Y0-BKEA00
Reviews
Related Products
