cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Delta RGB Gaming Headset with Hi-Res ESS Quad-DAC, RGB Lighting Effect
Availability: In stock
  • Industry-leading hi-res ESS quad-DAC for impeccably detailed and true-to-life audio
  • USB-C connector for true multiplatform support, including PCs, Mac, mobile phones and PS4*
  • Customizable, multi-color circular RGB lighting lets you shine in style
  • Exclusive ASUS Essence drivers, airtight chamber and audio signal diversion technology for immersive audio experiences
  • Upgraded comfort with ergonomic D-shape and ROG Hybrid ear cushions
£179.99
Get 0% interest for 4 months
Learn More>
£179.99
Product Description
Clarity for the Win
ROG Delta White Edition is the world's first gaming headset with the industry-leading, hi-fi-grade ESS 9218 quad DAC, which delivers impeccably clear and detailed sound to give serious gamers the edge they need to win. ROG Delta White Edition features a USB-C connector and comes with a USB-C to USB 2.0 adapter to let you game on your PC, console and mobile device without changing headsets. A one-of-a-kind, circular rainbow RGB lighting effect provides a stylish look to set you apart on the battlefield.
Ultimate Immersion for Pro Gamers
Hear every detail
Hi-Resolution ESS 9218 Quad-DAC
Some people say there is no good sounding gaming headset. Those people have not heard ROG Delta White Edition. Four hi-fi-grade ESS 9218 DACs provide lossless audio processing with each DAC devoting its processing power to a subset of the audible frequency range, from lows, mids, highs to ultra-highs. The four signals are then combined, which produces clearer sound with an impressive 127-dB SNR that's much higher than any device in the market. As a result, you can hear and place in-game sounds with pinpoint accuracy, letting you precisely judge enemy distance, direction of footsteps, gunshot locations and more. Hear every detail and enjoy crisp, clear sound for a true-to-life audio experience.
Exclusive Hyper-Grounding Technology
Hyper-Grounding is ROG's exclusive technology, which utilizes a multi-layer PCB and a special layout design to prevent electromagnetic interference, resulting in pure, noise-free audio. Due to this innovative technology, ROG Delta White Edition is the world's first gaming headset with RGB lighting that is able to include an ESS Quad DAC and unlock its full potential to provide gamers rich, powerful sound unmatched by other gaming headsets.
High SNR in FPS Games
Signal to noise ratio is a critical specification for gaming headsets, especially in FPS games. A higher SNR allows you to precisely pinpoint the origin of enemy footsteps, or hone in on the location of gunfire or explosions on battlefield. With its quad-DAC design, ROG Delta White Edition is capable of achieving an unprecedented signal-to-noise ratio of 127 dB, a level untouchable by single-DAC gaming headsets.
Crystal-clear Highs and Punchy Bass
Next-Gen ASUS Essence Drivers
With ROG Delta White Edition, the exclusive ASUS Essence drivers have been updated with Audio Signal Diversion technology, giving them a circular wall that helps separate high, low and medium frequency sounds, reducing interference between frequency ranges for purer and clearer audio. Additionally, the drivers feature a wide frequency response of 20–40kHz to provide incredibly strong bass and optimized gaming sound, so you'll hear every detail while enjoying an all-around immersive acoustic experience.
Style at Your Command
Exclusive Circular Rainbow RGB Lighting
Show your style with customizable Aura RGB lighting. ROG Delta White Edition leaves single-color lighting behind as the world's first gaming headset to feature rainbow circular RGB lighting. This captivating effect features seven independent lighting zones with dazzling multicolor cycling displays. Choose from over 16.8 million color combinations and six preset lighting effects.
ASUS Aura Sync Technology
ROG Delta White Edition features ASUS Aura Sync technology, allowing you to synchronize lighting effects across Aura-enabled products to create a unique and captivating gaming atmosphere.
One Headset Is All You Need
Multiplatform Compatibility
Instead of a 3.5mm connector, ROG Delta White Edition features a USB-C connector and an comes with a USB-C to USB 2.0 (Type-A) adapter, which allows it to connect with nearly every gaming platform, including PCs, consoles and mobile devices, letting you enjoy its class-leading performance, anytime, anywhere.
Crafted for Comfort
Ergonomic D-shaped Ear Cup
ROG Delta White Edition has ergonomic, D-shaped ear cups that more closely match the shape of human ears compared to oval ear cups, reducing the unnecessary contact area by 20% for a better, more comfortable fit, especially when the headset is worn for long periods.
Angled for Better Comfort and Sound
The drivers inside each ear cup are tilted by 12 degrees, closely matching the natural angle of human ears. This sloped design not only provides better comfort, but also helps improve sound quality by enabling the audio signal to travel directly into the ear canal.
Two Types of Fit and Feel
ROG Delta White Edition provides two types of fit and feel for you to choose from based on your needs or preference. ROG Hybrid ear cushions, which combine protein leather and fabric mesh, are thicker, more breathable and provide a contoured fit, perfect for long gaming sessions. The protein leather cushions are comparatively thinner and softer, making them good for on-the-go use.
Instant Control at Your Fingertips
Intuitive control buttons on the ear cup let you instantly control volume and RGB lighting, and a durable rocker switch lets you easily mute the microphone during gameplay.
Certifiably Clear Communication
ROG Delta White Edition comes with a detachable, unidirectional boom microphone, tuned especially for clear voice communication and certified by leading communication apps. An indicator on the tip of the boom flashes red when the microphone is muted, letting you easily see the microphone's status.
Specifications
Specifications
SKU 90YH02HW-B2UA00
Model ROG Delta White Edition
Brand ASUS
Condition Status Brand New
MPN 90YH02HW-B2UA00
Reviews
Related Products
