cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS ROG Ryujin 360 all-in-one liquid CPU cooler with LiveDash color OLED
Availability: Out of stock
  • 1.77” color OLED for real-time system stats and personalized logos or animations
  • Embedded microfan helps to cool VRM and M.2 area by up to 20°C
  • Quality Noctua Industrial PPC PWM fans deliver high airflow and minimal noise
  • LiveDash one-stop control center for lighting and OLED display
  • Individually addressable RGB and NCVM coating pump cover accentuates the sleek, modern aesthetics
  • Styled to complement ROG motherboards, at the center stage of your build
  • Reinforced, sleeved tubing for increased durability
£234.99
0% interest for 4 months
Learn More>
£234.99
Product Description
ROG Ryujin is the flagship all-in-one cooler for high-end builds designed to deliver the best thermal performance. Featuring Noctua IndustrialPPC fans for cooler and quieter operation, plus an embedded fan in the pump housing for additional cooling to the VRM and M.2, ROG Ryujin keeps your system running its absolute best. Coupled with a LiveDash OLED that displays system stats or custom graphics and Aura Sync RGB lighting, ROG Ryujin is the ultimate thermal solution destined to become a vital part of your gaming rig.
COOL TO THE CORE
ROG Ryujin meets the thermal challenges of the latest multi-core CPUs with industrial-grade Noctua iPPC-2000 PWM fans on the radiator that deliver high performance and low-noise operation. The 120-mm fans generate 122 CFM of airflow at 2,000 RPM yet are extremely efficient with a 29.7-dB(A) acoustic footprint that's much quieter than competing fans.
Pump embedded fan
While powerful, liquid cooling does not circulate air around the CPU socket like a traditional heatsink and fan. ROG Ryujin overcomes this limitation with a 60mm fan embedded in the pump housing that circulates air to the CPU VRMs, M.2 slot and surrounding components to dramatically reduce temperatures for improved performance and stability.
NEXT LEVEL OF CUSTOMIZATION
LiveDash OLED
ROG Ryujin is the world's first AIO cooler to feature an embedded 1.77-inch LiveDash color OLED that displays useful system information*, such as temperatures, voltages, fan speeds, or frequencies. You can also customize LiveDash to display a customized image or animation** highlighting your clan insignia or gamertag.
Complete LiveDash customizability
The LiveDash software utility lets you easily customize ROG Ryujin's LiveDash OLED display and RGB lighting effects. Select which system stats to monitor, choose personalized GIFs and images to display, and control RGB lighting from an intuitive interface that arranges settings in a step-by-step flow from top to bottom.
Subtle, striking, sleek
Infused with Aura RGB lighting in dramatic slash patterns on the shroud, Ryujin exudes a vibrant glow that highlights the CPU at the heart of your build
PERFECT
SYNCHRONIZATION
The impact of Aura RGB lighting can be further enhanced with ASUS Aura Sync, which allows harmonized lighting effects with other Aura-enabled system components and external accessories. Aura software give you complete control of lighting across all compatible devices, letting you dial in the vibe you want to display quickly and easily.
EXTENDED COMPATIBILITY
ROG Ryujin is compatible with a wide range of Intel and AMD motherboard platforms, giving you the flexibility to pair it with your choice of processor. It also comes fitted with 38cm of tubing to make mounting and routing easier.
Specifications
Specifications
SKU 90RC0020-M0UAY0
Model ROG RYUJIN 360
Brand ASUS
MPN 90RC0020-M0UAY0
Reviews
Related Products
