cart 0
You have no items in your shopping cart.
0
You have no items to compare.
X
Age Confirmation
This option is only available for customers of age 16 or over. Please confirm by clicking the button that you are of age 16 or over. for more detail see Privacy Policy
I am over 16
ASUS TUF Gaming VG279Q1A 27" Full HD LED Monitor Aspect Ratio 16:9 Resp Time 1ms
Availability: In stock
  • Aspect Ratio: 16:9
  • Resolution: 1920 x 1080
  • Brightness: 250 cd/m²
  • Contrast Ratio: 1000:1 (typical)
  • Response Time: 3 ms (grey-to-grey)
  • HDMI, DisplayPort
£307.99
0% interest for 4 months
Learn More>
£307.99
Product Description
TUF Gaming VG279Q1A is a 27-inch Full HD (1920 x 1080) IPS display with an ultrafast 165Hz refresh rate. Designed for gamers and others seeking immersive gameplay, it offers some serious specs. But there's more ....
Its exclusive ELMB function features a 1ms MPRT response time and Adaptive-Sync (FreeSync Premium) technology, for extremely fluid gameplay without tearing and stuttering.
27 inch IPS display for better color reproduction
The 27-inch Full HD (1920 X 1080) IPS panel of TUF Gaming VG279Q1A delivers stunning visuals from all angles with wide 178-degree viewing angles ensure minimal distortion and color shift even when you're viewing from extreme positions.
Super−fast 165Hz refresh rate
An impressive 165Hz refresh rate eliminates lag and motion blur to give you the upper hand in first-person shooter, racing, real-time strategy, and sports titles. This ultrafast refresh rate lets you play at the highest visual settings and react instantly to what's onscreen.
*Select graphics cards/GPUs can support 165Hz graphics source output (via DisplayPort). Please note that this performance depends on the GPU or content displayed. Actual real-world performance is hardware-dependent.
Enjoy super−smooth gameplay
Features the latest ASUS-exclusive Extreme Low Motion Blur technology, which achieves 1ms MPRT* to eliminate smearing and motion blur, and makes objects in motion look sharper, so gameplay is more fluid and responsive.
*1 ms MPRT is based on internal test results. Actual response time may vary in real world settings.
High-flying design
TUF Gaming VG279Q1A has a stealth fighter inspired design that gives it a dynamic, futuristic look. The rear panel features wing-like elements, giving it a sensation of speed. A svelte, minimalist stand ensures stability and a touch of elegance.
IN−GAME ENHANCEMENTS
Intuitive controls
ASUS DisplayWidget Lite is a software utility that lets you easily and quickly tweak settings or configure ASUS-exclusive features such as Shadow Boost, ASUS GameVisual, and more.
See what's lurking in the shadows
ASUS Shadow Boost technology clarifies dark areas of the game without overexposing brighter areas, improving overall viewing while also making it easier to spot enemies hidden in dark areas of the map.
GamePlus
The ASUS-exclusive, integrated GamePlus hotkey offers in-game enhancements that help you get more out of your game. This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills.
Flicker-Free technology
Flicker-Free technology reduces flicker to minimize eyestrain for improved comfort when you're embroiled in long gaming sessions.
GameVisual
ASUS GameVisual Technology has seven pre-set display modes to optimize visuals for different types of content. This unique feature can be easily accessed through a hotkey or the on-screen display settings menu
Ultra-Low Blue Light technology
ASUS Ultra-Low Blue Light technology reduces the amount of potentially harmful blue light emitted by the display. Four different filter settings are available to control the amount of blue light reduction.
ENGINEERING
Rich connectivity
Enjoy extensive connectivity options, including DisplayPort 1.2, two HDMI (V1.4), and a 3.5 mm audio jack for connecting to a wide range of multimedia devices.
Ergonomic design
With an ergonomically-designed stand, TUF Gaming VG279Q1A provides tilt and swivel so you can easily find your ideal viewing position. The display is also VESA-compatible for wall mounting.
Specifications
Specifications
SKU 90LM05X0-B01170
Contrast Ratio 1000:1
Response Time 1 ms
Model ASUS TUF Gaming VG279Q1A
Brand ASUS
Condition Status Brand New
MPN 90LM05X0-B01170
Screen Size 27 in
Maximum Resolution 1920 x 1080
Manufacturer Warranty 1 year
Features Flat Screen, Headphone Jack
Reviews
Related Products
